implement a dynatrace monitoring
Dananjaya_Tech
Newcomer
How to implement a dynatrace monitoring on a specific domain environment
arturo_mondelo
Dynatrace Advisor
Dynatrace Advisor
Hi @Dananjaya_Tech,
You have it very well documented on our public documentation on how to create a Browser monitor using the Dynatrace Synthetic Recording
Of course you have other options to generate those, like the ones described Browser clickpath events | Dynatrace Docs and Script mode for browser monitor configuration | Dynatrace Docs, among other modes (Create an HTTP monitor | Dynatrace Docs) that are also available.
Those tests can be then executed on our Public Locations or within your own infraestructure.
Hope this clarifies your doubts!
