Can you be more specific what you want to try to monitor?
Availability of FTP service?
Data transfer (rate, throughput)?
Certain clients - if they have the connection?
Availability of FTP from the application?
What type of FTP server? Platform?
Anyway, there is no such functionality out-of-box, I believe you will have to write your own oneagent plugin for that you need to monitor the service in general. If you want to monitor the FTP service from the application point of view (your monitored application uses some FTP service), then it depends on the application and technology.
Hello @Surya G.
I guess you can use the HTTP monitors to check the availability. Please have a look at the below link for more insight and possible options.
Babar
Answer by Sushmitha S. ·
Even we want this feature added
Hello @Sushmitha S.
Babar
Thanks Babar. I am looking at something more specific. Can you help me with FTP URL availability using Dynatrace HTTP feature
Hello @Sushmitha S.
I took the below information from the shared link.
A Proxy Auto-Configuration (PAC) file is a JavaScript function that determines whether web browser requests (HTTP, HTTPS, and FTP) go directly to the destination or are forwarded to a web proxy server (from developer.mozilla.org).
Babar
Answer by Jeffrey S. ·
I would like to know this too. We have a critical FTP / SFTP server or service running in our environment that is KEY to the application health. Data / updates and feeds come in and are processed into the database. This data is then used in the APIs and webservices already monitored by Dynatrace. We monitor the apps, the webservices, the SQL server, but we have a blind spot on the SFTP server and the data feeds. We need to monitor this somehow and wonder if someone has already built an ActiveGate plugin or OneAgent plugin that can do FTP/SFTP
We also suggest , similar to other SaaS products like NodePing And PingDom and other services that SFTP/FTP protocol be added to synthetics. A synthetics test that could connect, and check for a file present, do a test upload or download of a small test.txt would be a GREAT addition to the Dynatrace synthetics tests.
One Agent support for monitoring IBM Integration Bus
Is it planned to support Python (Framworks like Django, Flask etc.) without any changes to the code?
We have installed Oneagent in my servers, but it is not monitoring my applications.
monitoring obsolete version of operating system
Is it possible to turn off RUM JS injection for ALL process groups?
