10 Feb 2024 03:32 PM
Hi Team,
As anyone please explain to me why the data fetched by API for the problem feed doesn't match the problem count shown in the Problem section.
Vikas A Goud
11 Feb 2024 10:22 PM
First thing that comes to mind is timeframe discrepancy. All API calls are in UTC and when you see it in the UI, it's typically your timezone.
03 Mar 2024 07:57 PM
Hi @AntonioSousa ,
Thanks a lot will check and set it as per timezone
