Citrix monitor with Powershell SDK
Candy
Guide
When I extended monitoring using the Powershell SDK monitoring mode, the following error was reported:
Python datasource initialization error: Exception("Could not run a test powershell script: 'NoneType' object has no attribute 'stderr'"),
How do I fix it? thank you.
RazTN7
Dynatrace Champion
Dynatrace Champion
@Candy
Ref from external site
If code is written like this
def get_shape_of_object(obj):
  return obj.shape
value = None
print(get_shape_of_object(value))
 should fix into below example
  if obj is None:
    return None
  return obj.shape
value = None
How to Fix AttributeError: 'NoneType' object has no attribute 'shape' (appdividend.com)
How to Fix the 'NoneType' object has no attribute: 'text' Error in Python - Nsikak Imoh
Cheers!
RN
Have a nice day!
