MonikaBalogh
Dynatrace Advisor
Dynatrace Advisor
TemplateId is required in the Launch job template action. Workflow execution fails if it's not provided.
Even with all mandatory fields provided, however, it's still possible for a workflow execution to fail. For example, a connection token could have expired, or the result of an expression could lead to an input that's considered invalid.
Version history
Last update:
‎20 Mar 2024 10:50 AM
Updated by:
